can i limit the cursor to 1 display when running dual monitors?
Not sure that this is a Labview question or more of a windows question. I am planning to build a Labview application that will use dual displays. One will be a touchscreen the other a standard monitor. I would like to use a mouse to change settings on the normal display but want to stop the cursor from running over onto the touchscreen. I know that i can make the cursor invisible and of no use on the touchscreen but ideally i would like the cursor to be bound within the limits of the normal monitor so the cursor does not get lost as such.
Any help/advice greatly appreciated.
Lucither
"Everything should be made as simple as possible but no simpler"
(3,124 Views)
Accepted by topic author Lucither
ClipCursor Function
Andrey.
(3,110 Views)
NVM - I read the post incorrectly
Bill
CLD
(Mid-Level minion.)
(3,093 Views)
Thanks Andrey,
Looks like this is what i need. I guess that i will have to write some software in VB.Net to implement this and have it running in the background? Will have to dust off my VB skills i think. Havent had time to actually play around with implementing any software to test yet as the project hasnt been given the green light.
Thanks again.
Lucither
(3,065 Views)
