can i execute the testing of adevice by using jtag on labview
all
i am trying to use the jtag for testing the device. but i dont know how to use labview for executing the jtag testing.
so can you please guide towards my work.
regards
Message 1 of 16
(4,848 Views)
It depends on the JTAG application package you use. Most of them provide a dll interface to execute tests.
So you basically develop your tests in the JTAG package and use the dll to run it. Here is an example from JTAG technologies: http://www.jtag.com/en/Products/Production_tools/PIP_packages?session=3h3pedo95mborts92svseai4v0
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 16
(4,847 Views)
Hello sir
I want to test my pcb bords ( it have arm9 processor)with jtag .so what the steps & connections are need to me  to test it functionalety plz...........give the solution........
Message 3 of 16
(4,788 Views)
Hello sir
Message 4 of 16
(4,782 Views)
@vanr wrote:
Hello sir
I assume you are the test engineer.  Those are details that *you* need to work out.  Let us know when you get to the LabVIEW part and I'm sure everyone will be more than willing to help here.
Bill
CLD
(Mid-Level minion.)
Message 5 of 16
(4,760 Views)
sir......
   I want  to test the pcb bords.at present we are testing pcb bords by using NI labview 8.5 .in my company products
There is to different boards analog boards and digital boards we test this two separatively and attached that two boards to work .In testing analog boards we measure electric parameters and functional parameters ,in digital boards we test the functional parameters .while measuring functional parameters we are keeping digital board constant and test the analog boards. vice-verse.(this work is doing with help of jigs,daq,and using serial port to read the data).and now my problem is to test the functional parameters to the boath the boards separatively( analog and digital boards) its taking long time (20 mints).so I want reduce that testing time plz give me solution..........
Message 6 of 16
(4,728 Views)
@vanr wrote:
sir......
Give you a solution???
That is your job as a test engineer. Are you getting paid to ask others to do your job for you?
Message 7 of 16
(4,710 Views)
hello sir...
I am not a employ sir I am a student . I am doing my project .In part of that I ask you a solution sir.
Message 8 of 16
(4,702 Views)
You ask for a solution but a solution is impossible to provide with so little information. Nobody but you knows what these two different pcb's are, what they do, their specs, how you are testing them now, what test equipment you have, etc. You asked about jtag and all you say is the type of micro that you have. Was the board designed with doing jtag on the whole assembly? Do you have any experience with jtag?
Message 9 of 16
(4,689 Views)
@vanr wrote:
hello sir...
So, it is okay to ask for someone to do your school project for you ????
At my university that is grounds for explusion since it an ethics violation.
Message 10 of 16
(4,666 Views)
