can digital x-ray camera can be interfaced with imaq hardware?
hi friends,
i want to know whether digital x-ray camera can be interfaced with imaq hardware.also for my system i need to interface two digital x-ray cameras, one digital camera along with daq card and motion control.is it possible?i need quick response.
(2,898 Views)
Theoretically yes, but it depends from the interface. May be you can use NI 1426-1429 framegrabbers in case if camera equipped with Camera Link interface. Otherwise may be you can use NI 1424 framegrabber. But before you must know details about digital interface. Which x-ray camera must be connected to framegrabber?
Andrey.
(2,894 Views)
I agree with Andrey.
Most likely we can connect your camera to IMAQ hardware, but its impotant to know what the camera is going to output.  With information regarding the connection type and signal properties, you should be well equipped to select the correct board.
Let us know if you need help selecting a board!
Robert
(2,885 Views)
