can anybody teach me how to use pict ring to draw or import picture?
need help in using pict ring.i need to draw electric circuit to be insert in my front panel.
Message 1 of 14
(3,855 Views)
  1. LV Menu >> Import Picture to Clipboard... >> Select the picture
  2. Right-click on the Pict Ring >> Insert Picture from Clipboard
Step 1. is superfluous if the picture has already been copied in the clipboard with another software.
Feel free to post back if you need further help.
Message Edité par JB le 03-05-2008 05:47 PM
Message 2 of 14
(3,849 Views)
if i draw the picture from multisim,then i paste it in paint,after that i can import it in front panel by using the method u told just now is it?
Message 3 of 14
(3,847 Views)
Not all graphic formats may be supported (don't remember exactly) but yes for the principle. See also the comment I have just added to my previous message.
If possible, use pictures of the same size.
Message Edité par JB le 03-05-2008 05:52 PM
Message 4 of 14
(3,840 Views)
sir,i want to draw a circuit that is similar to the one i'm attaching.in the example,when u click on the circuit.u can choose either to have R & L component or R & C component.i wish to do the same.i just know how to use the pict ring but i can't get it to change.could u plz take a look at the vi.thanks.
Message 5 of 14
(3,833 Views)
Hi neerza,
The steps for customizing a pict ring are described in my previous posts. What is your exact problem ?
Message 6 of 14
(3,804 Views)
dear sir,regards to the question,i have been able to use the pict ring.thanks for your help.do u mind if i ask another question?how to insert a sub vi in a vi?
Message 7 of 14
(3,802 Views)
This is very easy. 2 common ways :
  1. Functions palette >> Select a VI... >> select a VI and place it on the diagram
  2. Drag&Drop a VI from the Project Explorer to the diagram (LV8.x)
Message 8 of 14
(3,794 Views)
its the same for labview 7.1 also?
Message 9 of 14
(3,792 Views)
Hi neerza,
yes, it's the same for older versions of LV (except that the project explorer is new to LV8+ Smiley Wink)
You may also drag a vi from one opened block diagram to the next... Or drag a vi by it's icon (upper right corner of front panel) to a block diagram (not it's own...).
Message Edited by GerdW on 03-06-2008 11:12 AM
Message 10 of 14
(3,787 Views)
