can a 6211 read rising and falling edges of an analog input
When I go into the windowed measurement of an analog input the rising and falling edge triggers are grayed out. Is this unit capable of detecting rising and falling edges of a analog input channel.
I am trying to control a relay with this I was planning on triggering a digital output but if I have to I think I can use a analog output If that makes a difference.
All help is appreciated
(2,869 Views)
Duplicate post in Instrument Control board
(2,858 Views)
Hi Pinton,
It does not look like that card has analog triggering capabilities.  You can always do the triggering in software if you don't mind a short delay.  If you want to see a list of our products that have analog triggering in hardware, here is what I would do.  Go to http://www.ni.com/dataacquisition/ and you should see options to narrow down your search.  One of the options is triggering.  If you click on Analog, you will have a list of all devices that support analog triggering.   Then you can narrow down by bus and whatever else you need.  Here is a direct link to to all of the USB analog triggering devices:
http://sine.ni.com/nifn/cds/view/main/p/sn/n22:an,n24:USB/lang/en/nid/1036/ap/daq
Scott
Scott G.
AE Specialist
(2,856 Views)
