can NI PXI 5154 could be used to interface accelerometer
Dear Sir
I want to measure the vibration using the accelerometer. The cable of the accelerometer is co-axial and BNC type connector. I would like to ask whether I can interface NI PXI 5154 with my accelerometer? The NI PXI 5154 is plugged in the NI PXIe-1082.
However, In MAX when I select analog signal and then the accelerometer, the system says no supported device.
Much appreciate if you could advise the solution.
Thank You.
Kind Regards
Irfan
Message 1 of 1
(2,237 Views)
