can I use variables in case structure range?
Let's say I have a case structure that switches on a number.  Obviously I can define a range for a given case, i.e. 0..4, 5..8, 9..100.
But what if I want those ranges defined by variables?  i.e.
MIN_A = 0
MAX_A = 4
MIN_B = 5
MAX_B = 8
MIN_C = 9
MAX_C = 100
is there a way to create a case structure to where I can enter those variables as the range?
I know an alternative woulud be to simply compare the number to those ranges and switch on true-false and nest the case structures, but didn't know if I could do it directly as described above.
Message 1 of 8
(4,064 Views)
Wow, that's a good question!  It seems like a very useful feature though.  Of course it begs the question of what happens if conflicting ranges are entered during run-time.  Smiley Frustrated
Now I'm curious as to what some of the LabVIEW gurus around here are going to say about it...
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 8
(4,058 Views)
put those numbers in an array and use Interpolate1DArray to find the corresponding range!
It takes care of overlapping ranges - somehow… 😄
Message 3 of 8
(4,053 Views)
This is interesting question.
I think you could wire in your min and max variables to couple of 'In Range and Coerce' functions, and based on the outcome generate an enum value for example. Then you can use that enum wired in to a case structure.
Message 4 of 8
(4,047 Views)
I think what you really want is Threshold 1D Array.  That will give the "index" of the value you give it.  It does assume a constantly rising array, but that shouldn't be much of an issue.  Then you just put this index into the case selector.
Message 5 of 8
(4,025 Views)
I'd go for 3 In range and Coerce, and an AND to combine them. Maybe there's a slimmer way.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 8
(3,984 Views)
/Y
Why the AND?  Or do you mean Build Array and then Boolean Array to Number?
Message 7 of 8
(3,970 Views)
@crossrulz wrote:
/Y
Unless i misunderstood, there are 3 different variables that needs to be in range, bool array to number would also be a solution if the other combinations are of interest.
/Y
Qestit Systems
Message 8 of 8
(3,953 Views)
