can I set different input range in different channel in cFP AI100
Dear Sir:
I have one question about the input range of cFP AI 100. Can I set different input range for different channel in one cFP? Also, can I set different input type (voltage or current) for different channel in one cFP? If yes, how? Thanks.
Best Regards.
Fred
(2,859 Views)
Hi Fred,
The answer to both questions is yes. In MAX, in the Channel Configuration Tab of your cFP-AI-100, you can specify your range to be one of a number of settings for current or voltage. To configure separate channels, simply select the channel and then select the range. See the attached screenshot for more details.
Sean C.
(2,854 Views)
Is it possible to set the range when you are communicating with a cFP-1804 over an RS-232 line?
(2,591 Views)
