camparing encoder count
hi
I am reading an encoder and counting the pulses, with a display value which updates every 100ms.
 After a certain interval, the encoder count stops incrementing.
How can I save the encoder count at one  instant and compare with the count after an interval passes(e.g. 1 second )  to determine when the count stops increasing?
(3,649 Views)
make a ringbuffer with
a) a subvi see example somewhere in XY-Graph
b) a queue
c) if you have LV-RT using the RT-FIFO
another way is attached
Greetings from Germany
Henrik
LV since v3.1
(3,640 Views)
hi thank you for your help. that is good solution.
(3,619 Views)
