camera triger
Hi
I am planning on using the camera's trigger for send LVTTL volt but after run the program I see the error that attach here.
I need help outputing a  LVTTL signal from the  trigger to my camera(Apogee camera). Any help would be greatly appreciated.
(3,055 Views)
This is because there is no board id specified, and the control does not know what hardware interface to update. To fix this, place a property node and set the Board ID prior to making calls to the methods for the board. The following link you can find an article that gives more information about the error that you receive:
http://digital.ni.com/public.nsf/allkb/EBA7E2E1653D1E0B86256C5A00505292?OpenDocument
(2,968 Views)
Hi
tanks your reply, but my camera (Apogee camera-Alta U2 CCD) has not this property. I mean I want to use Board Id but it can not support that!
I use LabVIE 2012
how can I use that?
Regards
(2,962 Views)
