camera frame grabber to laptop
Hi everyone,
I am using a frame grabber connect a camera to a laptop. The camera is Dalsa Piranha2 linescan, it is said that programmable integration time, line scan rate,... and there are commands for this through serial port. Can you show me how to send these command to changes camera parameters?  How should I do that in Labview?
Hannah
(2,702 Views)
Hi Hannah,
if this properties are settable through serial port, you can first check to send this commands through hyperterminal. If this works see the shipped examples "Basic/Advanced Serial Read and Write.vi".
Mike
(2,692 Views)
