calling labview dll from fortran lf95
I have a huge legacy app. written in Leahy LF95 fortran. I have GPIB instruments that I want to communicate using Labview from within the fortran code. I have created a labview 8.5 dll with my GPIB functions. I call them from the fortran app. Everything compiles and links just fine. I go to run the app and everything is fine until the call to Labview Runtime engine. I get a generic Error 998 blah blah blah runtime engine problem. This is a National Instruments error message NOT Fortran. I tried creating a MS VC++ 6.0 wrapper dll that simply calls the Labview dll thinking it might be an interface problem. Same error. I am very frustrated at this point and question the viability of Labview in any of my future projects that involve Fortran which is a huge # of projects.
(3,760 Views)
Hi BoeingJR,
This is not a LabVIEW error, but rather is related to the way the DLL is being called.  Please see these links for more info:
KB:
Why Do I Get Error 998 when I Try to Call a DLL in LabVIEW?
Related forum post:
I get error 998 when calling a LabVIEW buildt DLL from MSVC++
Hope this helps.
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(3,733 Views)
Thanks for the input...there is something squirrley about the Labview Run Time Engine. I rewrote my Labview VI's using labWindows 8.5 and created a LabWindows DLL. Using the same _stdcall protos I don't get the error when I call the LabWindows functions form Fortran!!!! . I'll stick with LabWindows until they figure out the problem
(3,724 Views)
Hi BoeingJR,
If you could post a project (simplified as much as possible) illustrating the error so I can reproduce it on my end, it would helps us determine if it is truly a bug and, if so, what needs to be done to fix it.
Eric V
(3,700 Views)
Thanks Eric V...I'll create a simple Hello pgm in LF95 with a call to a Labview DLL...I'll post it ASAP
(3,689 Views)
EricV....Here I sit begging forgiveness from the Labview gods.... I wrote a quick console "Hello" app in fortran (LF95) that called a labview vi from a labview generated dll. It worked fine. I took it a step further and created a Fortran "Windows" app using Wisk and called the same Labview VI. Worked fine. I can only think that my large legacy app has some major memory leaks or allocation issues. I will have to start disecting the old fortran code until I find what is trashing the Labview RunTime Engine. Fortran coding should be illegalized with heinous punishment dealt to those who wish to defy.
thanks again
(3,681 Views)
Hi BoeingJR,
You're very welcome.  I'm sorry to hear that there wasn't a simple fix.  Good luck, and let us know if there is anything else we can do to help.
Eric V
(3,654 Views)
