calling an event structure via a LED?
Thank you altenbach,
I will try that in the next version.
The attached version has some other modifications and they work quite good.
I fixed another bug as well: Using the quotient and remainer was no good idea, it caused problems during changing the X scale time.
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
Message 21 of 28
(1,305 Views)
@Alain:
Which help? LabVIEW Help? Online help? Where can I find that VI?
Greetings Johannes
Message 22 of 28
(1,302 Views)
Try the example finder. 😉
Message 23 of 28
(1,296 Views)
johanneshoer wrote:
@Alain:
Yes, the find examples from LV 🙂
Attached a "lean" version of your code using the XY Chart.vi from the help.
I agree that I may delete too much especially regarding the zooming but can't you just use the graph tools to zoom in?
Message 24 of 28
(1,282 Views)
Hi Alain,
thanks for the help. Could you please save that VI in LabVIEW 7.1 Version?
Greetings Johannes
Message 25 of 28
(1,253 Views)
Hello Johannes,
I don't have 7.1 and 8.6 on the same PC 😞
If someone else can, please feel free to convert... ...
Message 26 of 28
(1,219 Views)
No problem, a screenshot would also be fine Smiley Happy
Greetings Johannes
Message 27 of 28
(1,209 Views)
Here are the screenshots but I think the sub VI is useless since I can't stretch it 😞
Message 28 of 28
(1,186 Views)
