calling RegisterDeviceNotification function
Hello Everyone,
I need some help to figure out how to call this function from Labview.
Details about the prototype are found here
I know how to use the call library function but I can't figure out how to wire one of the parameters that happens to be a struct _DEV_BROADCAST_DEVICEINTERFACE( here)
In C++, what I am trying to do translates into this code :
DEV_BROADCAST_DEVICEINTERFACE NotificationFilter;
    GUID_CLASS_USB_DEVICE.Data1 = 0xA5DCBF10L;
    GUID_CLASS_USB_DEVICE.Data2 = 0x6530;
    GUID_CLASS_USB_DEVICE.Data3 = 0x11D2;
    GUID_CLASS_USB_DEVICE.Data4[0] = 0x90;
    GUID_CLASS_USB_DEVICE.Data4[1] = 0x1F;
    GUID_CLASS_USB_DEVICE.Data4[2] = 0x00;
    GUID_CLASS_USB_DEVICE.Data4[3] = 0xC0;
    GUID_CLASS_USB_DEVICE.Data4[4] = 0x4F;
    GUID_CLASS_USB_DEVICE.Data4[5] = 0xB9;
    GUID_CLASS_USB_DEVICE.Data4[6] = 0x51;
    GUID_CLASS_USB_DEVICE.Data4[7] = 0xED;
    NotificationFilter.dbcc_size = sizeof(DEV_BROADCAST_DEVICEINTERFACE);
    NotificationFilter.dbcc_devicetype = DBT_DEVTYP_DEVICEINTERFACE;
    NotificationFilter.dbcc_classguid = GUID_CLASS_USB_DEVICE;
    RegisterDeviceNotification(hWnd, &NotificationFilter,
        DEVICE_NOTIFY_WINDOW_HANDLE);
I know how to get the hanlde to the Vi window and pass it as argument to the function. but I can't find a way to create the struct that I have to pass as second argument.
Any help will be greatly appreciated.
AJ
(3,953 Views)
I went through many posts of this forum that were related to my questions and tried putting something together to properly call this function.
I tried wiring a cluster that matches the Struct datatype required by the function. My efforts were not successful as the function appears to be reporting NULL. ( according to MSDN,
If the function fails, the return value is NULL. To get extended error information, call GetLastError.)
I get this error when I call the kernel32.dll
GetLastError(void);
ERROR_INVALID_DATA
13 (0xD)
The data is invalid.
My code is attached. any help or guidance is really appreciated.
thanks
AJ
(3,931 Views)
I just realized that some may need a prior version lf labview. I attached v 8.6 here
(3,881 Views)
Hi mam1nej,
Are you able to successfully run the C++ code you wrote and call the kernel32.dll in C++? Also, are you able to run your code using an example code? There is a code called External Code (DLL) Execution.vi that is located under Help >> Find Examples... on your LabVIEW splash screen, and you can find it by searching for the keyword "DLL".
Also, here's some information on using cluster data types in LabVIEW: http://www.ni.com/getting-started/labview-basics/data-structures#Clusters
Let me know what your results are and if this is helpful!
Francine P.
Applications Engineering
(3,830 Views)
