calling DLL using LabVIEW 7.1
so, i have this DLL which might be compiled using Visual Studio 2003 or Visual Studio 2005.NET.
question is: Can i call DLL functions using LabVIEW 7.1? has anyone tried it and has any issues loading the DLL?
i think i have everything right, as far as the configuration of 'Call Library Function Node' is concerned, but i get the
'error loading DLL - application has failed to start because application config is incorrect'.
can you please verify if .NET is not causing me issues? i think DLL assembly should be the same wheather it's VStudio6
or .NET, but can anyone confirm that's not the issue? Thanks...
(3,070 Views)
Yes.
If you dll is generated by C/C++, using Call Library Function node.
If it is generated by .net, using constructor node.
http://forums.ni.com/ni/board/message?board.id=170&message.id=206959#M206959
(3,057 Views)
rkpat:
I have successfully loaded dlls into LabVIEW before. Please post again if you run into any snags.
Rudi N.
(3,041 Views)
