call the owning VI multiple times
Hi all,
I'm trying to call the owning VI multiple times and wasn't sure if it's possible.I trying to call the same VI within a VI with different condition.
I have this VI as a template with reentrant enabled (VI_1), and inside the loop, it will call another instance of this template (call it VI_2) and wait until called VI (VI_2) completes and proceed to next action. The problem is wait until done doesn't wait although I set it to True. Can someone tell me what I'm doing wrong? or even this is possible.
Thank you in advance.
(2,473 Views)
Accepted by topic author tgif73
So the VI is calling itself?
If so you can drop the VI onto it's own diagram if it's set to reentrant in LabVIEW version 2009 and later.
Ton
My LabVIEW Ideas
(2,448 Views)
