call library
Greetings and Happy New Year to all!
I'm working on a program where (among other things) I want to read a shared memory resource. By means of some scripts running between my machine and another on the same network, a specified chunk of memory on my machine is being fed live data, and I want to access that data to manipulate it.Once I have access, I think I'll have to dump it into a buffer before I can start working with it, but thats getting ahead of myself....
For now, I've found the "call library functon node" that I think I can use to access the .dll file that has the functions I need to read and interpret the data being passed to me. Where I could use some direction is what to do with this? I somehow have to tell LV the "name" associated with the shared memory, yes? And somehow I need to tell LV what the data is...or would this be done through the functions in my .dll? [I think the answer there is the dll - and yes, I realize you all can't really know without seeing the code; I'm asking more in a general sense.]
Using this function node looks like a straightforward method. Anyone know of a better method for accessing shared memory?
Thanks!
________________________________________________________________________________
**Still looking through other threads; if this has been answered elsewhere, please let me know!
**This is all on LV 7.1.1...  😛
(3,116 Views)
Accepted by topic author IceMan30
Thanks!
Your thoughts are all correct! The answer is in the DLL and we can't help you at all without having lots more details about the DLL.
Rolf Kalbermatter  My Blog
(3,097 Views)
Worked it out with my in-hosue C++ guru...good to go! I ahd it set up pretty much correct, just needed the right .dll to call to.  🙂
(3,065 Views)
