call library function node function
你好, Labview版本為6.1,
      做一簡單的dll檔, 用call library function node 出現function not found in library錯誤,
      不知道錯誤為何?   附上附檔,請幫忙解惑,謝謝
(3,077 Views)
You have a *.cs file so most llikely are generating a .Net assembly, not a Win32 PE shared library. As such you need to use the .Net functions in LabVIEW to interface to it, not the Call Library Node.
Rolf Kalbermatter  My Blog
(2,968 Views)
