call library function node: array as pointer!
Hey!
I want to connect a dll from a call library function node (clfn) with a pointer to an array. Fill the array in the dll and then put the array as an output from the clfn. How do I do this?
/Jakob
(3,343 Views)
See if this helps you, I tried to do screen captures of it. I call my dll with a "CLFN" pass in an itialized array and then the dll populates the array which is outputted. I also included a screen shot of the configure settings for my particular array.
Hope it helps.
-Dave
(3,334 Views)
Thank you very much!
/Jakob
(3,329 Views)
