call library function configouring difficulty
I am working with the a USB based DAQ device (Cypress EZ-USB FX2LP) My card vendors now provided a DLL file. Calling convention is standard calling (_stdcall).
There are more than one functions in the DLL and more than one of the functions within the dll use same variable. In such a case How to configoure call Library function node. When I endup configouring all the variables, I see the C prototype as having all the variables in each of the function.
I am not good at programing languages, can any body please give a solution to this. I need it to be done urgently and it is very important to me.
my VC++ source file for dll is attached with this.
Thank you in advance.
Upendar.
(3,612 Views)
Hi Upen,
Are you getting any error codes or broken arrows in your code? Also, have you tried looking at the following article to use the call library function node?
An Overview of Accessing DLLs or Shared Libraries from LabVIEW
http://zone.ni.com/devzone/cda/tut/p/id/3009
Please let me know. Thank you!
Steven
(3,590 Views)
Hi Steven,
Thanks for the response,
I am facing the problem like, LabVIEW is crashing when I read from variables. I doubt there is a problem with the C prototye itself. Since there are more than one functions this problem shows up.
(3,572 Views)
From my limited knowledge, it doesn't look like you've exported any of the functions. Using _stdcall is not correct. Have you read the 'Using External Code with LabVIEW' document?
(3,565 Views)
Thank you for the response,
Dennis, as I mentioned earlier it was not the dll i prepared and it's a third party dll (my daq card vendor provided the same).
And in "using external code with LabVIEW" it is mentioned that we can call functions with any of the two conventions 'C' or 'standard calling (WINAPI)'.
Please anyone respond ...
Upen.
(3,551 Views)
Upen.
Your original request is more than unclear. Please specify in more details what you want to do and what does not work. Otherwise it is simply a shot in the dark trying to help you.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,543 Views)
