call imageprocessing functions
is it possible to call imageprocessing functions from other libraries like OpenCV?
(3,803 Views)
Hi muks,
if you have a dll you can use the "Call Library Function Node", or you can use the "Code Interface Node" if you have c code.
Hope it helps.
Mike
(3,800 Views)
Hi mike,
           I havent used either of them.Can you elaborate a lil bit?
(3,797 Views)
Hi muks,
with the "Call Library Function Node" you can call the exported functions of the selected dll. For example the user32.dll to get the current mouse position. If you have c code you can use the "Code Interface Node".
Mike
(3,793 Views)
Hi, muks,
It was discussed here: Using OpenCV library in LabVIEW.
Use search with OpenCV string - this will give you some links. Smiley Wink
Andrey.
(3,788 Views)
Thanx andrey.Was exactly what i was looking for
(3,767 Views)
