call chain from error cluster
Hello dear readers,
I have stumbeld into a problem where I need to extract call chain from error clusters that are generated by labview VIs and native functions.
Here is example of 2 completely different results:
Source by definition should mean origin of error, why sometimes I see error description added into it if it can be extracted by error code??
If other strings are added how can one separate call chain from other informations ?
I could not find documentation how this string is generated and how to format source string back to call chain that will work in all cases.
Message 1 of 10
(6,824 Views)
I agree with you that the error information should be consistent.
Now, I'm not apologizing for NI but, the error guts have been changed a few times over the history of LabVIEW.  For instance the Error Ring disappeared in Version 8.0 and reappeared with enhanced functionality in 2012.  The older sources and functions just could not make use of the features found today.  The ini configuration API was reworked for 2009 I don't know why the Developer of that chose such a poor error number and description.  (Since He worked on the Error Chain feature too!)
NXG has had exactly the same concerns and should be quite a bit better about that.
"Should be" isn't "Is" -Jay
Message 2 of 10
(6,810 Views)
Hi Pawhan11,
I don't believe you can guarantee that every error cluster has the call chain on it, but if you are the one defining the errors, you can use the function "Error Cluster from Error Code VI". This has a boolean input for show call chain which you will want to set to true. In this case, source does not refer to a place of origin, but the thing which caused the error; both are valid definitions.
Message 3 of 10
(6,807 Views)
The reason I am asking for this is that I want to have EH that will better fit to my needs, since many error coses appear in other external drivers and then it is a mess with error cluster. I have defined simple Error class on top of error cluster that allows me to add custom errors without necessity to pay attention to error codes since errors are device/module specific. When I add error myself I know for sure what was the call chain. When LV creates error it is unclear how this call chain is inserted into source... and that is the only thing that I am missing to convert error from labview error cluster into my error class.
I am trying with random NI vis and I can not see clear pattern of what content is to be expected (in this case no call chain only vi name inside vilib):
Message 4 of 10
(6,798 Views)
That one will have a description in <LabVIEW>\resource\errors\English\Analytics and Machine Learning-errors.txt or within <Program Files>\National Instruments\Shared\Errors\
Those are the two locations that are used to hold xxx-errors.txt files when you use tools>>Advanced>>Edit Error Codes...
A shame that they cannot hold format specifiers like the Error Ring can (today)
Message 5 of 10
(6,790 Views)
I have made simple VI that gets all NI errors divided into groups and descriptions based on error code (assuming it is unique). The problem is with call chain. Why this vi gives only name to itself when error appeared in Vi that is in Subvi, in the same subvi like screenshots from first post?
Message 6 of 10
(6,785 Views)
Bad assumption.  The error codes within a family name must be unique (more that one file can contain errors for the same family name but, that's bad practice).  1 error file can also contain errors for more than 1 family name but, that is bad practice too (installers install them with the installed build so its better to go with 1 family name per product and one product per error file)
So, duplicate what the innards of the error ring dialog do (or just use THAT it's open) and store them as variants of class data Family Name, Display name, Code, and description.
Message 7 of 10
(6,778 Views)
Interesting, in general error handling we have ErrorCodaDatabase vi that calls dll that gets error code description based on error code. If NI decided to have the same error codes in for example say 2 groups how this function determines which one to get based only on error code?
For example this error code from LV exists within 2 families:
They mean more or less the same so that is not a big problem
Message 8 of 10
(6,750 Views)
Explain errors shows both
Message 9 of 10
(6,729 Views)
Thanks, by explain error You mean right click on error cluster?
I must admit I have never known about this after 5 years of LV programming 🙂
How Can I use this feature programatically? The only reference I could find was:
https://forums.ni.com/t5/LabVIEW/Possible-to-return-the-quot-Explain-Error-quot-string/td-p/2227456
It refferences to general error handler which is based on getting error description based on error code.
Message 10 of 10
(6,709 Views)
