call ToggleDesktop.scf
you can toggle the desctop (close all windows),
the script for that is:
[Shell]
Command=2
IconFile=explorer.exe,3
[Taskbar]
Command=ToggleDesktop
the file (e.g. ToggleDesktop) has the extension
".scf" (works not on plain NT4.0 or on win95)
Now my question, how can I give the command
ToggleDesktop?
I found a way, but I wonder, if there is a better
way. I put the command "call ToggleDesctop.scf"
in batchfile, without this trick I was not able
to start the script with "System Exec.vi".
Do you have an idea? Best regards, Stefan Pofahl
(4,669 Views)
Wire the following to the command line input of the System Exec VI:
cmd /C "c:\i386\show desktop.scf"
NOTE: The scf file and path will be different in your case.
Khalid
(4,669 Views)
