call DLL which has user-defined types
Its a c++ templete class.  This I know for sure.  Not to be confused with the c++ complex (not templete) class.
From the header file I have:
typedef struct _C_double_complex
 { /* double complex */
 double _Val[2];
 } _C_double_complex;
So it looks like its a struct, who has a 2 element double array....maaaaaaaaaybe.
Message 11 of 14
(805 Views)
Hmmm, LabVIEW does have Complex Double data type. Maybe I can do something with that. The guy who wrote the DLL says that the complex is a number with real and imaginary parts. I'll have try it both ways and see how it goes or doesn't go.
Thanks for all the help.
Message 12 of 14
(799 Views)
LabVIEW stores complex numbers indeed as two floating points besides each other. This does resemble the C++ template you did show earlier and I think it is a save bet that this should work at least memory wise. But real and imaginary part may be switched between LabVIEW and your C++ template. Only trial and error will show.
Rolf Kalbermatter  My Blog
Message 13 of 14
(795 Views)
Just wanted to update this thread with news that I had success configuring the Call Library Function Node input parameter to Type = Adapt to Type and Data format = Array Data Pointer for the complex number array.
Just in case anyone else encounters this in their work.
The DLL was compiled with Microsoft Visual Studio .NET 2003.
Message 14 of 14
(781 Views)
