caliing My Computer in LabVIEW
Somil wrote:
Hey man, Do not say it a favour. Everybody has contributed and everything has a right on it.
 So here is what i found out.
Actually, the windows can be explored from the Web Browser ActiveX control. This is the basic thing. You just can make it more meaningful by adding more controls and other things of your choice.
I am attaching the VI along.
Strange it 100% equal to the solution I pointed to in one of my postings whistling.gif. Well anyway I am glad you solved your problem
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 31 of 83
(2,777 Views)
Ya, it is the same one inspired by you.
Somil Gautam
Think Weird
Message 32 of 83
(2,769 Views)
Hi somil,
I have labview 8.5. Will you please post your  vi in 8.5 version?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 33 of 83
(2,753 Views)
ya sure.
here it is
Somil Gautam
Think Weird
Message 34 of 83
(2,748 Views)
You will find it here in any 8.x format
http://decibel.ni.com/content/docs/DOC-2042
Message 35 of 83
(2,748 Views)
I think the very first reply points indirectly to the llb you mentioned. 🙂
My Bad... Please ignore...
Message Edited by NitinD on 23-09-2009 04:05 PM
Message 36 of 83
(2,729 Views)
Sigh, I was looking forward to some god old-fashioned flaming
Message 37 of 83
(2,725 Views)
Hi somil,
Can you explain how you have done it? A bit of documentation in BD.Smiley Happy
How you got "My computer" screen ? What i should select  from Activex objects?
Gaurav k
CLD Certified !!!!!
Message 38 of 83
(2,725 Views)
Ya, sure.
i will be explaining each and every detail of the code.
1. Select an ActiveX container. Right click the container to insert the ActiveX  object.
 2. Under the create control menu, select Microsoft Web Browser option. Also, place some boolean buttons on the FP (see VI)
 3. Next you have to go on the block diagram side and dance there Smiley Wink
 4. Just select the automation open function. link the container and the function.
5. next i have used invoke nodes inside the case selector for linking the boolean buttons on the FP. put everything in side a while loop
 I think that should explain you the code.
Somil Gautam
Think Weird
Message 39 of 83
(2,720 Views)
Yup. ThanksSmiley Wink
Gaurav k
CLD Certified !!!!!
Message 40 of 83
(2,704 Views)
