calculate CRC16 (my algoritm)
Can you please tell how to calculate the CRC. on this code:
unsigned short CRC16(unsigned short crc, unsigned char byte)
unsigned short carry;
carry = 0xFF & ((crc >> 😎 ^ byte);
carry = carry ^ (carry >> 4);
return ((crc ^ (carry << 4) ^ (carry >> 3)) << 😎 ^ ((carry ^ (carry << 5)) & 0xFF);
Thank you!
(4,825 Views)
Hi Sergiv,
you will find a lot of "calculate CRC" threads in the forum! Did you look for and did you check their examples?
Did you know
- you can use boolean logic on integer numbers like U8?
- you can do shifts using "logical shift" function (in the numerics palette)?
Following those two advices it should be easy to convert that C code into LabVIEW/G...
(Can't look at your VI due to the LabVIEW version you use.)
(4,822 Views)
thanks for the answer
I tried to make the example, but I did not succeed.
I never programiroval in C.
resave your vi in version 8.6so, and I ask for your help
(4,818 Views)
Accepted by topic author Sergiv
Hi Sergiv,
I don't claim "it's correct now" but I tried to follow your C algorithm...
Due to upload problems (forum doesn't accept VIs anymore...) I had to change filename from "*.vi" to "*-vi"!
(4,812 Views)
thank you
(4,807 Views)
When this happened??
I have attached a VI, couple of minutes back...!! Smiley Surprised
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,801 Views)
Hi moderator,
it happened at the time given in the message header...
This happens for me since some days and I already complained in the "Forum feedback" thread (as several other people too)!
(4,791 Views)
