cRIO module
I have a incremental encoder I am trying to read, It has 1024 pulses per revolution and is a push-pull type. It can both sink as well as source.
Here are the specs:
        Optical encoder, bidirectional w/index, 1024 ppr, servo mount,5-26V in, 5-26V push-pull out. Danaher Ind Crtl series H20.
I need to know what cRIO module could and would be used to read this.
(2,871 Views)
Whenever you have a question in what hardware or software would suite best to your needs, you should directly call your local NI office to talk to an engineer.
However, I would suggest a 9401.
Christian
(2,860 Views)
How many channels do you need?
Kareem W.
Web Product Manager
(2,848 Views)
