cRIO does not reset
We are using cRIO 9024 for a particular test application for the past many months. We are running a FPGA code and calling it from a host VI.
Recently we noticed that even after the application (ececutable) has been stopped, the last values remain on the outputs and the connected motor/drives keep running when they shouldn’t. I checked the code and there is a reset invoke method being used as well for resetting the values and as mentioned it has been working as desired for quite some time.
I tried resetting the cRIO from the controller and MAX as well but still the last output analog voltage was found using the multimeter.
Any suggestions?
Message 1 of 1
(2,320 Views)
