cRIO automatically stops after a few seconds.
Hello Everyone,
I am using cRIO-9045 with DAQ-Assistant to acquire data in LabVIEW 2019 from the NI-9252 voltage input module from all the channels (a0-a7, total 8 channels) at a sampling rate of 25000 Hz. I found an interesting trouble during the data acquisition. My VI automatically stops during data logging after a few seconds (approx. 15 seconds, file size 13  MB). When I increase the sampling rate, it stops after 5 seconds, and the file size saves around 3 MB. When I decrease the sampling rate to 1000 Hz, It runs continuously, for at least 5 minutes.
My question is, is there any buffer size limit in cRIO that gets full and stops automatically? If yes, how to program the VI to get rid of this?
I am attaching VI and some files for your reference.
(1,199 Views)
Accepted by topic author suraj9735
Most likely error has occurred and your code does not have any error handling.
I would recommend avoiding using DAQ Assistant. Use shipping examples instead. See Take Your First Measurement in LabVIEW Real-Time (Data Logging)
https://tmesystems.net/
(1,169 Views)
I have one update on this problem but don't know the answer to this logic. I have changed the saving of files from .lvm to .tdms and it works fine.
(1,098 Views)
ZYong already gave you the answer long before you stated that you don't know the logic behind what happens.
You do no error handling and just hope that everything will always go well. However when logging your data to disk in series with reading it first from the DAQ device, you slow down the loop so much that the data buffer between your application and the device is filling up. Once it has filled up, the task goes into error and won't resume operation until you reset and restart it.
Rolf Kalbermatter  My Blog
(1,090 Views)
