cRIO Unable to Undeploy and return system to a good state
I'm on a 9067 which is a linux chassis.
You don't happen to know where the config file sits on the 9067, do you?
Message 11 of 14
(2,436 Views)
I was having the same issue; Caused by a mismatch between the actual system and my project.  Actually, I intentionally left the Chassis and EtherCAT device out of my project because my application is designed to be flexible and programmatically detect the hardware modules and connect to I/O variables.
When I try to run from the dev environment, it ALWAYS pops-up the Conflict Resolution dialog, stating:
At least one deployed item is no longer in the project.
You can use the "Project & System Comparison" dialog box to view the missing items. Cancel this operation and right-click the target item in the Project Explorer window and select Utilities >> "Compare Project & System" from the shortcut menu to launch the "Project & System Comparison" dialog box.
The default 'conflict resolution' that is selected on the dropdown box is 'Undeploy all missing items'.  If I leave it like this and click 'Apply', deployment will fail as you describe.  If I switch the option to 'Do not undeploy the missing items', then deployment succeeds without error!
If you're attempting to do a similar thing - expecting project/system mismatch - I hope this solution works for you too.  I don't expect this solution to work (nor do I recommend it) if you require your project to match your system deployment.
Message 12 of 14
(2,418 Views)
The method of removing the files works, here's the full path that was missing from the last post.
\var\local\natinst\deployfwk\config
I deleted all the xml files in the location. They were recreated when a added the ECAT master and scanned the network in my labview project. I have my crio mapped in windows to get to these files.
Hope this helps someone.
Message 13 of 14
(865 Views)
Hello, Regis,
now i tried your guide and for me it is fully functional.
Thanks.
Message 14 of 14
(406 Views)
