10-23-2008 04:38 AM
Hi !
I developped a very simple application acquiring analog signals and switching on/off digital outputs using a cRIO. Data is transmitted to the host program through shared variables.
I created an executable from the code to be ran by the cRIO, set it at "Run at Startup" and deployed it.
I did the same thing with the host program and created an installer from the exe. As I'm using shared variables to transmitt acquisition result, I placed them in the support directory (data) when building the executable (Distribution.exe).
This executable perfectly runs on my computer.
I used the installer to install the program on another computer. This computer as its IP adress in the same subnet as my computer. But the shared variables never deliver other data than their default values so I guess there is a communication problem...
Can somebody help me ?
10-23-2008 07:23 AM
Hi zyl7,
Thanks for the post.
This seems to be a ducplicate...
My answer is on the other thread.
Kind Regards,
