cRIO (Linux RT) doesn't shutdown
Hey,
When I try to shutdown my RT Linux using "shutdown now" command in terminal. shutdown process is stopped (see picture) and cRIO is not shut down.
Any idea to fix that ?
Thank you
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(3,267 Views)
What are you trying to do exactly?
Turning off the hardware? If yes, I don't know how to do that.
It seems like the "shutdown now" cmd only stops the software.
I SSH into my Linux RT Target, and sent "shutdown now", the target replies "going to maintenance mode"
Epictetus
Antoine Chalons
(3,250 Views)
Hi Titou,
I just want to stop OS without turning off the power.
I 'd like to have running services stopper as clean as possible.
Having a service that not stop at shutdown could be a clue that something is going wrong on the OS. Not a good think when you want your app to run 24/7 🙄
Olivier Jourdan
(3,243 Views)
I don't fully understand what you're trying to do, have you seen this : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kHDxSAM&l=en-GB
Epictetus
Antoine Chalons
(3,235 Views)
