cRIO, Labview Uninstallation Issue
I installed Labview and the cRIO system on my machine on its SSD (by mistake). I tried moving the entire folder to the HDD but it caused problems.  I then moved it back to the SSD hoping all will be okay.
Now, I want to uninstall everything and reinstall onto the HDD, but for reason there is no uninstallation utility provided in the Control Panel.  My reason for reinstalling is because I am getting very explicit errors (some I have never seen before) when I am just doing simple applications. I assume this is happening because of the moving attempt of the NI folder.  I want to try to restart the software fresh onto the machine on the HDD.
Any suggestions?
Daniel
(2,511 Views)
If you need uninstall software of NI from your computer, you just need to open Control Panel and click on Programs and Features and double click on National Instruments Software. Then you are going to see a window where you can select the software that you need to remove and later you need to click on the Remove button.
(2,480 Views)
