cRIO IP access setting
I'm trying to set the denied IP access to my cRIO 9004, but not only to a single VI web page (from VI server: Access machine), but I'd like to deny the ftp access to the woole cRIO's VI server page at specify IP adress.
Do yuo know how to do?
Tanks a lot
(3,096 Views)
What you can do, as you may have been told by our AEs on the phone, is to apply a lock to the cRIO Remote System from MAX. Just open MAX>>Remote Systems>>[cRIOdevice]. In the Right pane of the MAX window, you have a "Lock" button at the top. Click it and insert a password. This password is applied to the system and anyone accessing the cRIO IP via ftp must provide username= guest and password = your_pwd, to access the cRIO.
Hope this helps,
AlessioD
(3,088 Views)
This is a good suggest. I knowed this mode and if I can't deneied IP access I will implement it.
Tanks a lot
(3,083 Views)
