cRIO CPU % Total Load Drifting Up...
My project has a cRIO 9074 in Hybrid mode (one Analog card is under the FPGA target, all others are scan engine).
The cRIO is a central controller to 3 modbus slaves (ModbusTCP function block palette [i.e. not the I/O Server]). And is a slave to 1 SCADA system via Ethernet/IP.
One of the slaves is an XP based HMI (not NI product) that is logging data to SQL DB. Which is how I get the plot shown. Weather I deploy dynamically, or 'run as startup' over the span of about 4 hours, the CPU % total load creeps upwards and rails. Eventually the HMI looses comms with the cRIO and stops logging data.
I have a feeling the culprit is the timed loops component of the total cpu load - but to confirm that, I will need to add it to the Modbus data to be logged.
The application has many timed and untimed parallel loops, some for the ModbusTCP comms, some for other logic - including a Queued state machine. During the four hours, the state machine is static - i.e. no transitions, and the size of data, as well as the polled frequency of data on ModbusTCP, and Ethernet/IP is also static. I do no programmatic changes to the data between the cRIO and the outside world.
Also, no logging to the cRIO disk. On an error, I may post a message to the console. (I'll check on that).
If this were your problem, how would you go about debugging it?
(3,172 Views)
Use the Distributed System Manager (DSM) to get more information, also about memory usage and the load balance between timed and untimed structures on your RT CPU.
(3,128 Views)
It is timed structures.
It is a memory issue (or so I would infer from what the console said)....
0x418a680 (LV TL[600]: Faults): memPartAlloc: block too big 11587600 bytes (0x8
aligned) in partition 0x32d4f8
0x418a680 (LV TL[600]: Faults): memPartAlloc: block too big 11595792 bytes (0x8
Sent source into NI. Will update this thread when I learn how I caused this.
(3,120 Views)
Accepted by topic author S1ack
per NI:
I used the system profiler tool to snapshot timing every hour or so. Smoking gun pointed to 2 vis. They were taking increasingly longer to execute, for one it's average excecuton time was 6.5ms (immediately after deployement) and 24.4 ms after about 4 hours - and it drifted up as the 'worst offender' accoding to the profler snapshot data. In this vi I was using the 'obtain queue' function - without an associated release queue.
I hardwired the queue reference to these vis. And so far 3 hours in and my CPU Total Load %  is holding steady.
(3,097 Views)
