cRIO 9802 conflit with 923x
I am using 3x 9233 and 1x 9237 synchronized, and stream the data to 2x 9802.  However, when I put the DAQ and 9802 save file diagrams together, the FPGA program hanges at the 9802 open file.
I am putting error out to each of the 9802 file open node, but non of them changes from the default value.  While the error out of the DSA settings are properly set to no-error after run.
Is it possible the exporting 12.8M clock interferences with 9802?
(2,861 Views)
Might be too late but this was fixed with NI-RIO 3.0.  Check out the KB here, for more information.
Basset Hound
(2,774 Views)
Glad to know it is solved.
I put those nodes in separated sequences, and solved too.
(2,760 Views)
