cRIO 9068 was crashing when the IMAQ Extract vi was used.
While I was running a data acquisition application I have noticed that the cRIO 9068  was rebooted after some time.
More specific, while I was acquiring images and using the project these images were cropped using the IMAQ Extract vi, the cRIO was rebooted.
A possible issue is that Labview is allocating more and more memory until it finally crashes.
Has anybody faced this issue before?
Attached you can find a test vi that I used to understand what was the issue. This test is taking an image and the cropping this image inside an infinitive loop while the performance of the memory is acquired. In addition, attached are some of the screenshots that I got when I plotted the memory and two of the messages that I got from the cRIO status report after the cRIO reboot.
Thank you in advance.
(2,709 Views)
Hi S_chris
Just to confirm. You had your crashes with a cRIO-9068 (Linux based x86) or with a cRIO-9082  (PharLap) based RT cRIO controller?
If you restart the system, is the controller working correct again?
Kind regards,
Andreas
(2,655 Views)
 Hi Andreas,
You are right. The cRIO is the cRIO-9082  (PharLap) based RT cRIO controller.
And yes, hen I restart the system is working fine again.
Thank you,
Christiana.
(2,644 Views)
