cRIO-9067 Real-time unexpected error restart (Hex 0x661)
Hey Wang_Liming,
we solved the issue after checking in the software for a memory leak.
We used the build array function in the software and it was replaced by the insert into array function and a pre allocated array that we know what the size of this one is.
After replacing the software with this we are now up and running for all the setups.
I hope this can give you a answer to your problem.
________________________________________________________________________
Problems will keep comming... Lets hope the answers do that to.
Never give up without a fight...
Message 31 of 32
(1,365 Views)
Thank you very much, we will try~~
now we use ethercat with crio to FESTO CMMT,but can only use scan mode.... FPGA can do nothing~~~
Message 32 of 32
(1,018 Views)
