cFP-2020 setting time/date
I am using Labview 7.0 + Real Time Module + MAX 3.0.
I want to configure the date/time on a cFP-2020 controller, I am using my computer running the Fieldpoint Software as a Time Server but it is setting the date/time exactly one day late on the cFP-2020. how do i configure the time service running on the host computer to be set to a certain time zone?
Thanks in advanced.
(3,110 Views)
Ok,
It just hit me that there was a Ni-RT.ini on the cFP-2020. After viewing the file, I found an entry called RTTarget.TimeZone under [lvrt]. 😃
Thought I would mention that In case anyone else has the same problems....
(3,110 Views)
Yes, that is a very good observation. You might also find the following useful though:
Setting the Timezone of a LabVIEW Real-Time System
This will save you from having to manually edit the ni-rt.ini file.
(3,110 Views)
Thats a great page, thank you.
(3,110 Views)
