cDaq9178 and application builder
Hello!
I've made and VI with LV8.6 which measures 12 analog channels (3* NI9125) and 8 digital (2*NI9435) and 3 digital inputs from two encoders (NI9411). The program runs good on the development computer with LV8.6. Then I've made an executable from it with application builder (we have LW8.6 FULL and separate Application builder). The executable runs good on the same computer but when I put it in a another computer it dosn't measure the analog lines. Only digital lines work. On some other topic (http://forums.ni.com/t5/LabVIEW/NI-9172-amp-Application-Builder-Problems/m-p/696481#M319131) someone had a similar problem and wrote that he had removed the custom scaling from the daqassistant (which I'm also using). I tried that and then it worked. Is there something that can be done so the custom scaling can be used with an executable or do I have to make the scaling after daqassistant? I have the same version of LV Run-Time (8.6.1) and MAX. And on the MAX I can see the measurements on both computers...
Message 1 of 1
(2,228 Views)
