cDaq-9132 (Features not available)
Hey I am learning to use the cdaq as an RT target. In the project explorer window it says that features are not available beside the cdaq-9132. Also when I right-click on the cdaq and click 'connect' nothing happens. I am using LabVIEW 2022 Q3 (64-bit) and have installed the Real-Time module 2022 Q3 (64-bit) module. The Real-Time module is on evaluation period.
I can't seem to deploy my shared variables either, the option to do so is missing. I have tried repairing the RT-module through programs and features.
How can this be fixed?
(803 Views)
Hi bilal,
did you install the needed device drivers ("hardware support") for your cDAQ?
Did you convert the OS of your cDAQ from WES7 to NILinuxRT? (As noted here.)
(778 Views)
Are you able to detect your cDAQ-913x under Remote Systems in NI MAX?
https://tmesystems.net/
(767 Views)
Yes I am able to detect it in NI MAX.
Also the OS has been changed and can also be seen in NI MAX that it's running linux RT.
(757 Views)
NI RIO Target Warning 'Features Not Available' In the LabVIEW Project
Some features of the LabVIEW Real-Time Module doesn't work in 'Evaluation' period. The module has to be activated.
(736 Views)
