cDAQ not running with executable/installer
Yes, I only need all of the files you created for your project, as well as the max configuration in a compressed folder.
Cheers.
Aldo H
Ingenieria de Aplicaciones
Message 21 of 26
(1,179 Views)
Sorry for the delay... All of the VI's should be contained within.
Message 22 of 26
(1,166 Views)
You're missing the .nce file, that has the DAQ configuration...Could you attatch it as well?
Aldo H
Message 23 of 26
(1,157 Views)
Sorry about that.
Message 24 of 26
(1,148 Views)
Ok, after reading one of the tutorials, I may have found a glitch in my process.  I wasn't getting all of the items checked in the exporter... Now the export document shows all of the channels under each module whereas before it was not.  I'll try and import this and see what happens.
C
Message 25 of 26
(1,136 Views)
Accepted by topic author chuggins1434
Ok, I figured out what I was doing wrong.
When I went in to export the configuration info from MAX, I was not checking all of the boxes needed to fully generate the export file.  One must select the appropriate Tasks from the Data Neighborhood section, the unit desired from the Devices and Interfaces section, and finally the used NI-DAQmx Scales from the Scales section.
I recompiled the configuration, exported it, and installed (imported) it on to my target computer and now all is well in the world.  My application works as intended.
Thank you all for the point in the right direction!
Robot Happy
C
Message 26 of 26
(1,128 Views)
