12-08-2017 06:16 AM
Hi @all,
i ll try to descirbe is at short as i can.
What do i have:
11x Thermocouple Sensors connected to NI9214
3x Voltage Sensors connected to NI9207
3x PT100 Sensors connecte to NI9216
What do i want to do:
calculating some heat transfer coefficient continously
How do i want to achieve it:
At first i want to meassure the volate to some specific value
When this value is reached i want to meassure some PT100 values to a certain point
-> when those values are meassured i want to start with the main calculation, MEAN of my thermocouples values and then some mathematics on it.
The Questions:
As i m quite new to LabView i want to know how to structure my code.
Constantly reading my sensors uses a while loop, but i have to pass the value somehow out of the loop, but not just the final value of my iterations.
Is it possible to run multiple tast in one vi?
I m currently using the DAQ Assist Block including all my channels, how can i split the channels to single signals and concerning this, how can i use this signals in different sequences or while loops?
I m really thankfull for any advice on my topic. Maybe there is some Function or Possibility labview offers which i haven t see yet.
Best Regards
Marco R
12-09-2017
01:03 PM
- last edited on
01-11-2025
02:05 PM
by
Content Cleaner
Hello MarcoRe,
Thank you for using the NI forums. Addressing your questions, I recommend you checking the next resources before you start developing your application:
Let us know your progress. All the best,
