cDAQ_9188 COMPATIBILITY TO WINDOW 10
Hi all,
is NI cDAQ_9188  2015 version compatible with window 10?
(2,745 Views)
The cDAQ-9188 uses the NI-DAQmx driver, and its 15.5.1 version is compatible with both Windows 10, LabVIEW 2015 and the cDAQ-9188.
However, I recommend you use the newest version of DAQmx that is supported by your software stack and the device. You can find required software here: Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT
(2,578 Views)
