cDAQ 9184 with NI9232 module for accelerometer and pressure sensor
I am trying to build a CompactDAQ system to measure two signals: vibration and pressure in pipeline system. The system will consist of the following: cDAQ9184 chassis, NI 9232 Module. IEPE accelerometer  to measure acceleration (vibration) and pressure sensor for pressure measurement. My question is: Can I connect the pressure sensor into the NI 9232 module? I found in NI website that this module is designed for acceleration and supports signal conditioning and excitation for accelerometers but nothing mentioned about pressure sensors. On the other hand the website mentions NI9237 module as the best choice for pressure sensors. So can I just use NI 9232 for both sensors or not.  Thanks
(2,399 Views)
(2,397 Views)
