c structure
Well, I'm certain that will NOT work:
You're reversing the order of everything in the cluster.
The first byte of the c structure will come out in the SPARE field.
You can't just willynilly reverse everything, you have to reverse bytes WITHIN each field.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 11 of 29
(2,338 Views)
Well, I reversed the postions of everything in the cluster - did you look at it before replying?
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 12 of 29
(2,338 Views)
Ok, here's the last bit illustrating the idea - casting a serialized C-stru directly to a LV cluster.  It may not be a great idea, but it's (possibly) feasible, on-topic, avoids element-by-element endian-handling - and it's all LabVIEW! Smiley Wink
Cheers!
Message Edited by tbd on 08-24-2007 10:49 PM
Message 13 of 29
(2,318 Views)
Well, I went by your picture - I don't have LV on this machine so I don't know what your code actually does.  My apologies.
As you said, it's not pretty, but I don't think there is a pretty solution.
Steve Bird
Culverson.com
LinkedIn
Message 14 of 29
(2,294 Views)
Thanks CMB - no harm done. Smiley Happy
... I don't think there is a pretty solution.
I can't imagine one, though, now somebody'll come-along and "blind-side" all of us.Smiley Wink
Cheers.
Message 15 of 29
(2,268 Views)
I'm looking at trying to develop a C/C++ TCP/IP client which has to communicate with a Labview TCP/IP server. I'm a bit worried about the actual data types I can use. Is there any utility out there that allows one to convert labview cluster data into C/C++ structs and also convert C/C++ structs to Labview data?  The labview server is already 80 % complete and uses a mix of cluster data types including variants.
The customer wants the client to look very professional and has insisted on C/ C++ or possibly C#.  Labview seems to have a lot of powerful facilities, so I think this is a problem that must have been solved in real world applications. Thanks for your help.
Message 16 of 29
(1,847 Views)
If you paln to use this data in different applications written in different languages it would be in your best interest to define a simple protocol for passing the data. Yes, you do get some over head but you avoid lots of issues of how each language represents the data. An easy and straight forward protocol would use a header which has a 2 or 4 byte data ID (this could also be a type) and a 4 byte length field. After the header you send the number of bytes given in the length field. If you want to send a structure/cluster you have a simple function that picks the data elements out and adds the header. Your list of data IDs is predefined and acts as part of your API. The nice thing about this is that it is very portable and allows multiple systems and languages to receive/send the data.
Another alternative would be to use XML. Either way, some representations of the data that is language indendent would be your best option. You would also have to agree on byte order. In that sense using network byte order is a safe bet.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 17 of 29
(1,835 Views)
A struct and a LabVIEW cluster are essentially the same thing; there's no utility needed for conversion.  LabVIEW may have opposite endianness from a C application running on the same machine, but it's not hard to byte- and word-swap.  LabVIEW may also align items within a cluster differently than C, but again, this is easily solved by adding dummy elements to the cluster as padding if necessary.
However, variants may be a problem.  I don't know how LabVIEW will send a flattened variant over the network; you'd be better off sending some header indicating the data type, followed by the variant data converted to a standard type.
Message 18 of 29
(1,833 Views)
Conceptually they are the same thing but they are not interchangeable on a byte level. Different compilers can pack and align things differently. It would be safest to either parse the data explicitly knowing how it is laid out or use a simple protocol as I suggested. I wouldn't rely on a simple LabVIEW typecast to convert a C structure into a LabVIEW cluster or vise versa.
Mark Yedinak
LabVIEW Champion
Message 19 of 29
(1,831 Views)
I wouldn't use a typecast, but, assuming all padding is correct, unflatten from string will work and can adjust byte order if necessary.  Compilers arrange data in standard ways - if they differed, we'd never get library calls working properly.  If a library does expect different packing it should put that explicitly in the header file.  I pass clusters to DLLs that expect structs all the time, and it works.  Going over the network isn't terribly different.  Not that there's a great difference between our suggestions - the layout of a flattened cluster essentially defines a simple protocol, it just happens to be one that should require very little parsing in C.
Message 20 of 29
(1,829 Views)
