c-series PWD
Is it possible to configure a C Series module, such as the NI-9485, to perform pulse width modulation (PWM) programatically using labview ( dynamically , real time)?
(2,992 Views)
Accepted by topic author Canucks.canucks
Hi canucks,
Yes, there are modules allowing configuration of PWM outputs.
such as the NI-9485
No, not this module.
1. Whenever you have questions on NI hardware you should read the manual first
2. When you are asking for a specific problem you should also supply specific information! Please define PWM frequency and desired PWM duty resolution…
After reading the manual of your NI9485 it is quite clear this module will only allow very slow PWM frequencies in the order of <0.1 Hz, as it is limited to "1 operation per second" switching rate!
(2,963 Views)
Thank you very much for your help. Sorry I meant pulse width module
(2,947 Views)
