byte to string array
Dear,
I need to build a string containing 205 bits from an array, any idea what is the simplest way to do that?
Tahnks in advance for your help
(4,366 Views)
Typecast?
(4,359 Views)
You don't say wat the datatype of the array is or how the string should look like. If the above does not solve your problem, we need more information. 😉
(4,355 Views)
Accepted by topic author BENIO
thanks for your quick reaction.please find the picture which explain more what I need to do.
(4,321 Views)
Sorry, I missed your response. Did you solve the problem in the meantime?
OK, this is a bit more complicated but still quite easy. Use a FOR loop and autoindex over the string array on the left.
Inside the loop, get the single-character substring from each of the three inputs on the right starting with [i] and reformat the main string element accordingly. Build the output string at an autoindexing output tunnel.
If this is not clear, please attach a simple VI containing your controls with reasonable default data.
(4,289 Views)
Hello altenbach,
Yes I have solved the problem by using a FOR loopand using string subset and replace the entire array.
It is working now.
Thanks for your advise.
(4,259 Views)
In the first post you asked for the "simplest way". This looks way too complicated and convoluted. I am sure it could be done with 80% less code. 😉
(4,240 Views)
