buttons
I make an application in labview 7.1. If I run this application on other pc, but with the same monitor resolution some buttons are otherwhere, then on my pc. For example I have a graph with slider below this graph, but on other pc slider move to the graph. Another buttons stay on its places. How shoul I do to slider stay on its place too?
Message 1 of 8
(4,476 Views)
Cound you show a screenshot image?
Most likely the problem is due to differences in default fonts on the two machines.
Have a look at the following link:
And also the links at the bottom of the above linked page. Good luck!
Message 2 of 8
(4,473 Views)
Thank you for your answer!
So I must on every PC change the font properties or is there another way how to set it through labview?
Message 3 of 8
(4,458 Views)
There is the picture of front panel with bad place of slider..
Message 4 of 8
(4,457 Views)
If you go to your VI properties->Window Size what settings are you using?  I would test mixing and match to see if that has any effect.
Brian K.
Message 5 of 8
(4,410 Views)
Then I see this: in the picture..
But I have already tried all combinations, without any effects.
Message 6 of 8
(4,383 Views)
Maybe there is something corrupt with that slider. (the rest of the panel looks OK, right?). Delete it and replace it with a new one. See if this helps.
Message 7 of 8
(4,368 Views)
the problem is OK if I change the font size in window apperance .(  according with settings in my PC). But I want to know  if it run without change this settings in windows...
Message 8 of 8
(4,362 Views)
