building an executable
Hi
I was wondering what are the steps in building an executable in Labview?
Thank you.
(5,084 Views)
If you look on the toolbar and go to Tools > Build Application or Shared Library (DLL)
Type in the EXE name that you want and where the supporting files will be. On the VI settings tab you can also choose whether it runs when opened, the abort button is show....
When your happy with it all click build.
Hope this helps
(5,079 Views)
Hi!
Is there a way to build an executable, or sometingth that works as a standalone, without the Application Builder? Maybe an application distribution library running over the run-time engine?
Thanks for helping 🙂
Isabel
(4,900 Views)
Hi Isabel,
What do you mean by "without the Application Builder"?  Once you create an executable, all you need is the Run-Time Engine.
When you build, you can choose to include the Run-Time Engine.  Or if you know that it is already installed, you can build without it (basically create an exe, only).  It is useful to create an installer which simplifies the task of installing the Run-Time Engine, etc..
The other thing to know is which version of LV are you using..  The steps of creating an executable have DRAMATICALLY changed since LV8.x.  (The CAPS are intended for NI)..  You need to do extra steps such as creating a project, etc,,,,etc,,,etc,,,etc,,,etc,,,etc,,  (sorry... it used to be simpler to create exe's...  - sigh - )..
RayR
(4,889 Views)
The Application builder exists for this purpose!!!
I doubt that the functionality you seek can be found in the LabVIEW Player... but you may as well read about it:
http://digital.ni.com/softlib.nsf/websearch/8685D06689B9A7D3862569B6005ED5C9?opendocument&node=132060_US
(4,889 Views)
Above is for Pre-LV8.x
LV8.x   =>  Tools > Build Executable.
Does it show that I preferred pre-LV8??  😉
(4,885 Views)
Thanks for your answers!
A collegue keeps telling me that he created a executable without the Application Builder... I was wonder if I had miss something...
Bye
(4,875 Views)
